Openmtbmap gebruikers
Moderator: Rogier
Madmaus
Mijn mountainbike: 26" Bulls 2012 copperhead 3
ma 1 augustus 2016, 17:25
Zijn er mensen die openmtbmap gebruiken als navigatiekaart?
Ik heb alle routing settings gezet zoals dat op de site van openmtbmap staat:
Road Type Avoidances
Interstates: don't avoid them, you'll miss the nicest trails.
Major Highways: If you tick it you will avoid streets that are nice for cycling, cycleways, cyclepaths, and so on. Well as you want to cycle with this map, I don't think you ever want to tick that box.
State Highways: Don't tick it. Most ways in the Openmtbmap would be blocked.
Residential Roads: If you tick it, then residential streets, primaries and secondaries are blocked as well as trails that are no fun to bike. May work, but don't bet on it (too often some very short residential street or bad quality trail is necessary to get from A to B without crazy alternations.
Unpaved roads: If you are a XC biker, then yes, try activating it. All ways with mtb:scale=1 or higher are blocked, as well as sac_scale = T2 or higher.
Dit alles in car mode.
Helaas krijg ik continu route berekeningsfout.
Voor rondom mijn huis (den haag) loopt hij al vast op hele kleine stukjes <2 km.
Het lijkt hem te zitten in de "interstates". Zodra die op avoid komt kan mijn garmin edge 1000 de meeste routes berekenen. Alleen ik begrijp dat je dit juist niet moet doen.
Wellicht is deze kaart meer iets voor in het buitenland.
