Specialized Stumpjumper
Berebeest
Mountainbiker
Mountainbiker
ma 7 maart 2011, 22:37
Hoi iedereen,
heb vorige week mijn nieuwe fiets mogen afhalen...
Het is een Specialized Stumpjumper geworden (weliswaar model 2010) volledig afgemonteerd met XT
ziehier de specs:
FRAME:M5 manipulated alloy frame, curved TT, SS w/ disc brake mount
ACHTERVERINGVORK: Fox Float F90 RL, 90mm travel, air spring, compression and rebound adj. w/ LO, alloy steerer
BALHOOFDSTEL: Campy style cartridge bearings for integrated alloy HT
STUURNOK: 3D forged alloy, adjustable rise, 31.8mm clamp
STUUR: Specialized XC flat, 2014 butted alloy, 660mm wide, 8 degree backsweep,
HANDVATTEN: Specialized waffle lock on grip (15.5/17.5) Specialized Thick lock on grip (others)
VOORREM:Avid SD-3R, linear pull, cartridge pads, lightweight compressionless housing
ACHTERREM: Avid SD-3R, linear pull, cartridge pads, lightweight compressionless housing
REMHENDELS: Avid FR-5, alloy, two-finger
VOORDERAILLEUR: Shimano XT
ACHTERDERAILLEUR: Shimano XT
SCHAKELHENDELS: Shimano XT
CASSETTE: Shimano HG61, 9-speed, 11-34t
CRANKSTEL: Shimano XT
TANDWIELEN: 44A x 32A x 22S, 4-bolt, 104/64mm
VELGEN: Mavic X317, black w/ eyelets, 28/32h
VOORNAAF:Specialized Hi Lo disc, CNC flange, sealed cartridge bearing, 9mm DT RWS, alloy QR, 28h
ACHTERNAAFCustom Shimano M525 SL, alloy QR, 32h
SPAKEN: DT Swiss 1.8mm stainless
VOORBAND: S-Works The Captain, 26x2.0", 120 TPI, tubeless ready aramid bead, dual compound
ACHTERBAND: S-Works Fast Trak LK, 26x2.0", 120 TPI, tubeless ready aramid bead, dual compound
INNER TUBES: Ultralight presta valve
ZADEL: Specialized Phenom, hollow Cr-Mo rails, thin foam, 15.5/17.5: 130mm, others: 143mm
SEATPOST: 2014 butted alloy, single bolt setback, 30.9mm
ZADELPENKLEM: 7050 hard annodized alloy collar w/bolt, 34.9mm clamp ID
Momenteel is mijn voorderailleur nog een SLX; de XT was niet binnen maar ze gaan hem vervangen bij het eerste onderhoud...
Hij rijdt fantastisch!!
Mijn vorige fiets was reeds 13 jaar oud en had nog geen voorvering. Je kan wel aannemen dat er een wereld van verschil tussen zit.
Laatst gewijzigd door Berebeest op ma 7 maart 2011, 22:52, 1 keer totaal gewijzigd.
stevens
Mijn mountainbike: Trek Superfly & Specialized Demo 8
ma 7 maart 2011, 22:41
Ik zie geen plaatjes 8)
Push Yourself Harder
Berebeest
Mountainbiker
Mountainbiker
ma 7 maart 2011, 22:43
stevens schreef:Ik zie geen plaatjes 8)
Weet het, het is mijn eerste maal en het lukt me nog niet....
stevens
ma 7 maart 2011, 22:49
hier staat het beschreven.
Berebeest
Mountainbiker
Mountainbiker
ma 7 maart 2011, 22:53
Bedankt,
het is me ondertussen gelukt :-D :-D
stevens
ma 7 maart 2011, 22:55
Wat is er met het buitenblad gebeurd, bij gestipt?
BikerBert
Mijn mountainbike: Sensa Livigno Sport 29er
ma 7 maart 2011, 23:47
Je componenten lijstje klopt niet. Er staan Avid remmen in de lijst op en de fiets zitten Magura HS33 op..Toch zie je niet vaak meer nieuwe fietsen met V-brakes en/of Magura HS33 langskomen..
Wel een mooie fiets, dat wel..
Life itself cannot give you joy
Unless you really will it.
Life just gives you time and space
Its up to you to fill it.
RobSter
Mauntainbiker
Mauntainbiker
Mijn mountainbike: Giant Anthem 29er1
ma 7 maart 2011, 23:56
Laat ze maar lullen..
Mooi fietsje met een prima afmontage heur... :-q
Aegis X.O
Mijn mountainbike: Giant Trance 2, Fox Talas RL, SRAM X.O
wo 9 maart 2011, 01:10
Mooie fiets! Fietst ook fantastisch.
Heb je deze in Leeuwarden gekocht? Ik heb voor een vriend van mij op exact dit type Stumpjumper een proefrit gemaakt. De verkoper bood een HS33 set aan (in de aanbieding). Zou wel heel toevallig zijn!
Zelf vond ik de HS33 set niet nodig. De Avid V-brakes waren al enorm krachtig, mijn inziens had de HS33 geen meerwaarde.
Veel plezier op de Stumpy!
Tweemeter
Mijn mountainbike: Giant XTC 29er 2011
wo 9 maart 2011, 11:28
Mooie fiets, ik hou wel van zwart en/of wit. Ik zou nog wel even die "frisbee" achter je cassette weg (laten) halen :wink: .
Berebeest
Mountainbiker
Mountainbiker
vr 11 maart 2011, 17:25
Aegis X.O schreef:Mooie fiets! Fietst ook fantastisch.
Neen, ik heb deze gekocht bij L'express in het centrum van Antwerpen
Berebeest
Mountainbiker
Mountainbiker
vr 11 maart 2011, 17:26
Tweemeter schreef:Mooie fiets, ik hou wel van zwart en/of wit. Ik zou nog wel even die "frisbee" achter je cassette weg (laten) halen :wink: .
Wat is eigenlijk de functie van die "frisbee" en waarom zou ik ze moeten weghalen??
Ik dacht dat dit diende om eventueel vuil tegen te houden..???
Tinman
Mijn mountainbike: Van Nicholas Redwood Ti + Scott Scale 700 SL
vr 11 maart 2011, 21:00
De funktie is dat je ketting niet tussen je spaken komt. Er is geen rede voor om deze weg te halen. Het staat volgens velen hier minder stoer. :wink:
markje
vr 11 maart 2011, 21:33
Het is inderdaad niet stoer en het is veel makkelijker schoonmaken zonder dat stuk plastic. Mooie bak verder!
