Na veel wikken en wegen tussen die ongeveer 10 merken en meerdere modellen per merk
Op kantoor nadat ik m heb opgehaald.
2e rit in Malmedy
Specs:
FRAME FACT 9m carbon, 29" Trail Geometry, FACT IS construction, tapered headtube
ACHTERVERING FOX/Specialized remote Brain w/ AUTOSAG
VORK RockShox Pike RC 29, Solo Air spring, 130mm travel
BALHOOFDSTEL 1-1/8 and 1-1/2 threadless, Campy style upper with 1-1/2 lower, cartridge bearings
STUURPEN Specialized XC, 90mm, 6-degree rise Deba 60mm stem
STUUR Specialized XC, mini rise, --> Renthal Fatbar Light 780mm 20mm Rise
HANDVATTEN Specialized Sip Grip --> Ergon GE1 Blue
VOORREM Shimano XT BR-M785, hydraulic disc, 200mm rotor
ACHTERREM Shimano XT BR-M785, hydraulic disc, 180mm rotor
REMHENDELS Shimano XT BL-M785, hydraulic, alloy lever
VOORDERAILLEUR SRAM X7, --> vervangen voor OneUp NW single ring 32t
ACHTERDERAILLEUR Shimano XTR Shadow Plus, 10-speed, GS mid cage OneUp RadCage
SCHAKELHENDELS Shimano SLX, 10-speed, trigger
CASSETTE SRAM PG 1050, 10-speed, 11-36 OneUp 42t granny
KETTING SRAM PC 1051, 10-speed, w/ PowerLink
CRANKSTEL Custom SRAM S-2200, --> SRAM X0 Carbon
TRAPAS SRAM, PF30, OS press-in bearings, sealed cartridge
PEDALEN Specialized Boomslang flats
VELGEN Roval Control Carbon 29, carbon disc, hookless bead, 22mm internal width, 32h
VOORNAAF Roval Control Carbon 29, 15mm thru-axle, 32h
ACHTERNAAF Roval Control Carbon 29 142+, DT Swiss Star Ratchet, 12mm thru-axle, 32h
SPAKEN DT Swiss Revolution
ZADEL Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
ZADELPEN Command Post IR, 3-position height adjustable, 30.9mm, 125mm travel
ZADELPENKLEM Specialized 7050 alloy, single bolt, 34.9mm
SWAT SWAT Technology compatible (not included)
GPS Garmin Edge 1000
