eTrex Legend/Vista HCx software version 2.50 beschikbaar
faxe
Wellictht ten overvloede maar er is een nieuwe update 2.50 van de software van de eTrex Legend/Vista HCx, te downloaden op:
eTrex Legend HCx: http://www8.garmin.com/support/download ... sp?id=3707
eTrex Vista HCx: http://www8.garmin.com/support/download ... sp?id=3709
Heb deze update geinstalleerd in mijn vista en heb het idee dat ten opzichte van de vorige software versie de ontvangst ook iets verbeterd is.
Dopehead.NL
Mijn mountainbike: Specialized Stumpjumper FSR 29er
Volgens Garmin hebben ze alleen het volgende aangepast :
Changes made from version 2.40 to 2.50:
* Removed the turn backlight on action when unit is initially powered on.
Staat niks bij over verbeteringen in de ontvangst, maar wie weet zijn ze dat vergeten te vermelden.
RobSter
Mauntainbiker
Mauntainbiker
Mijn mountainbike: Giant Anthem Advanced non-Pro 29
Tnx had voor de Etrex Venture van mij nog de oude..
Ga nu de nieuwe even patchen. Er zijn nogal al wat aanpassingen :
Changes made from version 2.10 to 2.30:
Change number of lines of text in the address field on map feature review page from 4 to 6.
Limit number of custom POI bitmaps to 64 to ensure enough memory resources.
Added better compatibility with Mac computers in USB mass storage mode.
Changed datum used in the SWEREF 99TM grid from GEO_NAD83 to GEO_NONE_GRS80.
Changed datum used in the Estonian grid from GEO_NAD83 to GEO_NONE_GRS80.
Fix potential shutdown when using TOPO West 1999 due to some map ids being duplicate.
Corrected French translation for 'Log track points'.
Improve track log recording for sensor products to continue recording sensor data even when GPS doesn't have a fix.
Fix potential shutdown when propagating in a cul-de-sac across a map boundary.
Add A905/D900 unlock code communication protocol.
Improve the current margin when changing the backlight brightness.
Improve the road network when try to generate it for large diameter speed cameras.
Correct Swiss grid issue and postcode issue with CNE v.9 NT.
Modify 'Lithium Ion' text to 'Lithium'.
Fix WebUpdater issue of GPS firmware.
