Transfer Routes to GPSMAP 4208
Moderator: Rogier
Gesloten
jamesrivard
ma 19 juni 2017, 14:13
Hello,
I have a feeling this question will go unanswered and I understand why. The GPSMAP 4208 is a brand new marine gps network chart plotter just released by Garmin. I'll give it a shot anyhow.
I created a route on my pc at home using mapsource, the file was saved as a ".gdb" file onto a blank sd card. I brought the sd card to my boat and plugged it into the 4208. The unit did not recognize the file and so I was unable to upload the route to the 4208. Is there anything else I can try?
Thanks.
ma 19 juni 2017, 18:06
Use asecamp ?
dvdspelert
ma 19 juni 2017, 20:32
Did a quick search and found same post, been struggling for a while? http://www.gpsinformation.org/forum/vie ... =13&t=4248" onclick="window.open(this.href);return false;
Did you try other filetypes? .gpx is what my device uses. What does the manual say?
EDIT
A quick search I didnt find any filetypes in the manual. But I did find a restriction:
max 20 routes
max 250 waypoints per route (not much for mtb i guess, but I dont think you use it for MTB)
Maybe try to create a route in the device itself, and load that to the computer. See what filetype it is.
Then create a route with that extension and max 250 waypoints. Should be working I guess.
Good luck fishing!
Het hoeft niet moeilijk.
GT Karakoram 29er
RobSter
Mauntainbiker
Mauntainbiker
vr 23 juni 2017, 17:09
Lekker ding voor op het stuur :o
Patrick_V
vr 23 juni 2017, 20:06
En dat is zonder accu/generator :lol:
Tsjibiti
za 24 juni 2017, 10:56
jamesrivard schreef:Hello,
Thanks.
Je ne le peux pas lire. Quel est votre problème?
George
za 24 juni 2017, 11:15
Das ist doch nur ein spammer mein bester trol ;)
Gesloten
