Specialized Epic comp 2015 Satin Black/White/Hyper
van Tuyl
ma 8 september 2014, 23:04
Na 4 jaar tevreden gereden te hebben op een Epic expert 26 inch http://www.mountainbike.nl/forum/viewto ... 14&t=72770
nu overgestapt op een 29 inch Epic comp
Een paar detailfoto's
Speclist:
FRAME
M5 alloy, 29" geometry, tapered headtube, full internal shift/brake routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 100mm
ACHTERVERING
FOX/Specialized remote Mini-Brain w/ AUTOSAG, inertia valve, BrainFade adjust, 205x53mm, 100mm travel
VORK
RockShox Reba RL 29, Solo Air spring, tapered alloy steerer, w/ lockout, compression, rebound adjust, 15mm thru-axle, 100mm travel
BALHOOFDSTEL
1-1/8" and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
STUURPEN
Specialized, forged alloy, 6-degree rise
STUUR
Specialized flat, 8-degree backsweep, 31.8mm
HANDVATTEN
Specialized Sip Grip, light lock-on, half-waffle, S/M: regular thickness, Others: XL
VOORREM
Magura MTS, hydraulic disc, Hi Friction pad, alloy master cylinder, alloy caliper, Storm SL rotor, S/M: 160mm rotor, Others: 180mm
ACHTERREM
REMHENDELS
Magura MTS, alloy lever
VOORDERAILLEUR
Custom SRAM, 2X10, high direct mount
ACHTERDERAILLEUR
SRAM X9 Type 2, 10-speed, mid cage
SCHAKELHENDELS
SRAM X7, 10-speed, w/ MatchMaker clamp
CASSETTE
SRAM PG 1030, 10-speed, 11-36
KETTING
SRAM PC 1031, 10-speed, w/ PowerLink, nickel finish
CRANKSTEL
Custom SRAM S-1250, 7050 alloy arms, 10-speed XC double, PF30 spindle, 36/22
TRAPAS
SRAM, PF30, OS press-in bearings, sealed cartridge
PEDALEN
Resin test ride, w/ toe clips, CEN std.
VELGEN
Roval 29, alloy, 21mm inner width, 32h
VOORNAAF
Specialized Hi Lo disc, sealed cartridge bearings, 15mm thru-axle, 32h
ACHTERNAAF
Specialized Hi Lo disc, 4 sealed cartridge bearings, 12mm thru-axle, 32h
SPAKEN
DT Swiss Industry, stainless
VOORBAND
S-Works Fast Trak, 120TPI, 2Bliss Ready, folding bead, 29x2.2"
ACHTERBAND
Specialized Fast Trak Control, 60TPI, 2Bliss Ready, folding bead, 29x2.0"
BINNENBAND
Ultralight, presta valve
ZADEL
Body Geometry Phenom Comp, hollow Cr-Mo rails, 143mm
ZADELPEN
Specialized alloy, single bolt, 30.9mm
ZADELPENKLEM
Alloy, 31.8mm
Laatst gewijzigd door van Tuyl op vr 12 september 2014, 20:48, 2 keer totaal gewijzigd.
Aron B
di 9 september 2014, 00:07
Hele mooie fiets!
Fantastische dingen die Epics!
Veel plezier ermee :-q
QriZ
di 9 september 2014, 10:08
Heel erg gaaf! Heb zelf ook een satin carbon frame van Specialized; heel erg mooi.
Gaat het nu weer over het fietsen?
Biking Rebel
Locatie: BMC TE01 Teamelite 29r & Specialized CruX disc
di 9 september 2014, 11:12
Erg mooie kleurstelling. Strak en toch opvallend!
Sponsored by: MB Sports Wear
van Tuyl
di 9 september 2014, 11:53
Thnx voor de mooie reacties. Het hyper green is real life nog wel een stukje mooier.
Ik probeer vd week ff betere foto's te maken.
Biking Rebel
di 9 september 2014, 11:54
van Tuyl schreef:Thnx voor de mooie reacties. Het hyper green is real life nog wel een stukje mooier.
Dat klopt, ik heb de 2014 geheel hypergreen versie...nauwelijks goed op de foto te krijgen!
Eertje
di 9 september 2014, 12:41
Erg mooi en gave kleurstelling.
Wat weegt ie nu ongeveer?
van Tuyl
di 9 september 2014, 13:09
Eertje schreef:Erg mooi en gave kleurstelling.
Zal hem vanavond ff wegen
van Tuyl
di 9 september 2014, 17:49
12,8 kg
Koenuhhh
Locatie: Specialized Epic Comp (2015) - YT Jeffsy 29 (2017)
di 9 september 2014, 17:52
Mooie bike! :-q
Freediamond87
di 9 september 2014, 18:01
Mooie fiets hoor! Enig idee waarom Specialized de voorband in S-works uitvoering doet en achter in control? Omdat de control uitvoering wat duurzamer is?
Dennis78
di 9 september 2014, 20:08
Mooie fiets en veel plezier ermee
Biking Rebel
di 9 september 2014, 21:02
Freediamond87 schreef:Mooie fiets hoor! Enig idee waarom Specialized de voorband in S-works uitvoering doet en achter in control? Omdat de control uitvoering wat duurzamer is?
Achter is de belasting van de band zwaarder dan voor. Liever voor gewicht besparen dan achter. Soepele band voor geeft ook wat meer grip.
Shaggadellick
Locatie: 2014 Canyon Nerve AL 8.0 + 2017 Scott Spark 700RC Pro
wo 10 september 2014, 10:25
Nice :-q
pk-patty
Locatie: Trek Procaliber 9.7,Niner Jet 9, Trek 1.5 racert.
do 11 september 2014, 20:03
Mooie bike, maar hoe lang is die zadelpen wel niet???? :tong :tong
